The new Opel / Vauxhall Meriva is hard to beat in its class when it comes to variability: its door concept allows optimum access to the back, the FlexSpace system effortlessly provides a loading area which can be used for diverse purposes and a built-in bicycle rack is also available.
Regardless of how full the compact van is to be loaded: with the Eibach Pro-Kit Performance Springs there is always enough room for a generous amount of driving enjoyment. Guided by their balanced suspension, the Meriva negotiates through each corner safely and with sporty feedback. The appearance also profits from the reduction of the vehicle‘s centre of gravity. The outline of the car seems lower and more dynamic.
The car looks even more impressive with the Eibach Pro-Spacer Wheel Spacer. They come in different sizes and give the bodywork of the Meriva even greater performance.
All Eibach suspension components, which are available through authorised dealers, are provided with a high-quality corrosion protection and are TÜV-certified.
More...
