With the launch of the latest E-Class station wagon, Mercedes-Benz has set the standard in quality, space and comfort. A luxurious ambience, combined with impressive load capacity, make the E-Class station wagon a superb companion for long journeys.
True driving enthusiasts will relish the release of the latest Eibach Pro-Kit Performance Springs, which uses a pair of precision wound front springs to lower the car by around 30mm. The rear air suspension can then easily be reset to achieve the perfect stance – without affecting ride comfort – to achieve a car that looks far more purposeful and displays pinpoint handling characteristics.
The Eibach Pro-Spacer Wheel Spacer kit increases the vehicle’s track, not only making the wheel fill the arch for a real visual ‘kick’, but more importantly, creating a chassis that benefits from improved turn-in and sharper steering response.
All Eibach suspension components, which are available through authorised dealers, are provided with a high-quality corrosion protection and are TÜV-certified.
Continuar a ler...
