- Amplificador JL Audio 500/1 500W Class D Monoblock Subwoofer Amplifier
* Rated Power: 500 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
* THD at Rated Power: <0.05% @ 4 ohm
* S/N Ratio*: >95dB below rated power
* Frequency Response: 5 Hz - 500 Hz (+0, -1dB)
* Damping Factor: >500 @ 4 ohm/50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Dimensions: 13.4"L x 9.25"W x 2.36"H
* Differential-Balanced Input Topology: (1 pair of inputs)
* On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
* Bass EQ: variable boost up to 15dB
* Infrasonic Filter: Fully-Variable 24dB/octave from 15-60 Hz
* Signal-Sensing Turn-On: permits operation without remote lead
* Dual mono speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
http://mobile.jlaudio.com/pdfs/Slash_amps/500_1_MAN.pdf
O amplificador está um pouco riscado mas a trabalhar perfeitamente. O preço são 200EUR que é estrondoso para material desta gama.
Estou aberto a trocas: procuro umas colunas decentes de 13cm e um subwoofer razoável e qualquer outro tipo de material, façam ofertas.
