boas, isso da pa fiat punto mk2 1'9jtd de 2002. como é a nivel d montagem?
também no ebay pelo que me reservo o direito de cancelar a venda aqui.
preço base 90€
ERL Aquamist MF2- 3D Fuel injector driver kit.
This small controller will go beyond what any EPROM chip can ever dream of: it can control four high impedance injectors to flow enough fuel for up to an extra 200bhp!
MF2 - Map Fueler
ERL believe everybody should know exactly what they are getting before passing over their hard-earned cash; not merely a little piece of plastic concealing every bit of machine-code tailored to your car's ECU, unleashing all that hidden potential to achieve ultimate power. The MF2 is based on an open-architecture design, which means that the unit is freely re-programmable at any time, open to any one who possesses a small screwdriver: no computer interface is necessary! If this interests you, read on ... working alongside the original ECU, the MF2 controls its own set of injectors, four high-impedance injectors and two low-impedance injectors (not supplied). It is able to use the signal from the existing sensors, or it can operate independently. 3D-mapping is simple if a load- or pressure- signal is fed into the unit. We are not re-inventing the chip, but merely giving back the control to its rightful owner!
ta:se cafe snack bar
não dá.
obrigado, continuaçao...
ainda em venda
bumpbumpbump
negociavel
desenterrar o tópico... ainda tens isso?
Corsa T16 By X.T.S.
n, sorry esqueci-me d apagar isto. compra uma MS, ja n s justifica comprar isto :P
