Boas pessoal, tenho estes 3 alarmes para despachar.
Rolling Code - not FSK
Many 2 Way Alarm systems operate a FSK (Fixed Code) which means thieves could copy your fixed alarm code. As with pretty much ALL brand new cars, our system uses the very latest 'rolling code' technology.
Before buying a 2 way alarm system, please recommend you check if it is FSK or Rolling code to ensure your car security.
Turbo Mode / Short Run
Ideal for cars with Turbo Engines that need to cool down. This function allows you to programme your desired 'run' time before automatically killing the engine.
Keyless Entry
The system works just like a keyless entry system without any security function. You can use this function to remotely lock/unlock your door, open the boot or even use it as a car finder.
Remote Alarm - with vibration alerts
This kit will alert you remotely if your car is being tampered with. Three different programs depending on how your car is tampered with:
1) Light Impact: Horns sets off for 3 secs, lights flash, pager will alert / vibrate showing triggered area.
2) Heavy Impact: Horn sets off for 15 secs, lights flash, pager will alert / vibrate showing triggered area.
3) Illegal Door Opened: Horn sets off for 30 secs, lights flash, pager will alert / vibrate showing triggered area.
Multi-Level Security
Allowing you to decide which functions you wish to use and which ones you wish to dis-arm.
Immobiliser
For increased in-car security - protects against theft and hi-jacking. Alarm is set and lights flash for 16 seconds and then the engine will shut down even if the key is in the ignition. The system also cuts off ALL power therefore the engine can NOT be started again until the panic mode is dis-armed.
Standard Arming Mode
Press Button, 5 secs delay and the horn will beep, lights flash and door will lock.
Alerts on your pager will notifiy you of this.
Door Status Function
Incase you forgot to close your door or if it wasn't quite closed properly, this function will alert you via flashing lights.
Boot Opening
Opens your boot at a press of a button - up to 1mile away.
Status Memory
This kit will remember the status of the programe before power off. So, even if the power supply is destroyed, as soon as power is restored then the system will remember the previous settings.
Silent Arming Mode
This dis-arms the horn from the alert system but enables lights to flash whenever you press a button or shock sensor is triggered and the remote control will set beeping warnings. This also makes you free from the 'false' alarm which can be a nuisance in a residential area.
Real-Time Clock
Complete with Real-Time Clock which can also be used as a Personal Alarm - just like your mobile phone.
Key Lock Mode
Just like your mobile phone, you can lock your pager keypad so you do not accidentially activate a programme.
Other Details
Each pager is powered by 1 x AAA Alkaline Battery.
Designed for extreme cold weather conditions.
70€ cada, ja com portes incluidos.
