AWE has announced a nice upgrade for your TSI engine. The factory TSI turbo outlet pipe (a.k.a. pancake pipe), is not optimized for airflow.
With 30% more volume than the stock unit, AWE’s TSI Turbo Outlet Pipe will increase airflow and turbo response resulting in more power and quicker turbo spool. Testing on AWE's K04 powered Mk5 TSI showed gains of 5.75 crank horsepower and 6.9 crank torque with turbo response time cut down by half a second.
AWE's TSI Turbo Outlet Pipe features a mandrel bent all aluminum construction for unobstructed airflow and better heat transfer than the stock plastic pipe. The CNC machined aluminum coupler ensures a perfect seal with the stock intercooler hose.
Available in your choice of raw aluminum or black powder coated finishes.
Compatible with the factory intercooler piping or any aftermarket IC upgrade that uses a factory like coupler, like AWE's TSI S3 FMIC Hoses.
Compatible with the following vehicles:
VW Mk5 2.0T TSI
VW Mk6 2.0T TSI
VW Tiguan 2.0T TSI
Continuar a ler...
