An Audi S4 with its 333 compressor-PS is no mean thing on its own but the Swiss tuner thinks differently and by applying specific techniques has pushed the vehicle from Ingolstadt way over the 400 PS mark.
A newly programmed engine control and the installation of a sports air filter coaxes a full 425 PS instead of the standard 333 PS from the three litre V6 compressor. The maximum torque has also been distinctly increased by improving the electronics. Instead of 440 a maximum 520 Nm can now be called upon. A plus factor that is noticeable in the driving dynamics. Whereas the standard Audi S4 needed 5,6 seconds to accelerate from zero to 100 km/h the Sportec RS425 only needs 5,2 seconds. At top speeds, though, they are equal as both vehicles are electronically blocked at 250 km/h.
However Sportec is not content with solely an upgrade. A special sports silencer with four end pipes – two pairs on either side right and left – provide a more sporty sound. A braking system on the front axles enlarged to 380 millimetres ensures improved braking power. On the other hand chassis clearance has been reduced as Sportec has fitted the Audi with a suspension kit shortened by a progressive 25 millimetres.
In addition the Sportec RS425 is fitted with 9 x 20 inch large lightweight metal rims surrounded by 245/30 tyres. The Audi S4’s new look is rounded off with a diffuser at the rear and a spoiler at the front, both of which are made of carbon.
Continuar a ler...
