APR is pleased to present the Carbonio Carbon Fiber Intake System for the MK6 Jetta 2.0L 8v engine! The Carbonio Intake System is a ram air design that completely separates the intake filter from the engine bay and results in a peak gain of 7 horsepower! Building from years of experience on and off the race track, Carbonio’s and APR’s engineering teams have spent countless hours developing a true cold air and ram air carbon fiber design that can be recreated affordably for the street performance enthusiast.
For many years professional motorsport organizations have suffered great expense to properly tune the air intake delivery system for turbocharged engines for use in endurance and sprint races where every last horsepower and pound feet of torque can make the difference in position when crossing the finish line. Historically these designs have proven to be the most efficient and powerful although the most expensive to produce.
Aftermarket performance companies have attempted to capitalize on these designs however the cost restraints have typically resulted in compromise and deviation from the true engineering principles associated with motorsport accomplishment. Don’t be fooled by catch phrases and tag lines alluding to a new intake technology or special design characteristic. You won’t see any of these gimmicks installed on race cars at the Nurburgring.
Carbonio and APR have gone even further to maintain all oem specifications necessary to integrate cohesively with an otherwise stock engine to avoid raising eyebrows at the dealership. Flexibility was another characteristic of Carbonio’s and APR’s design whereas the new intake is also complementary to other performance modifications.
Constructed of aerospace grade carbon fiber and designed to remove intake restriction, APR’s Carbonio intake system provides smoother transitional airflow, increased air velocity, superior insulation of the incoming air to reduce intake air temperatures and a larger volume of available air to aid throttle response.
Benefits of the Carbonio CAI System include:
• Increased Horsepower and Torque
• Improved Throttle Response
• Improved Fuel Economy
• Enhanced Engine Volumetric Efficiency
• Enhanced Sound of Engine
• Installs in an Hour (does not require bumper or headlight removal)
• Maintains All Factory Emissions Components
• Fits Both Manual and Automatic Transmissionsc
• Fully Compatible and Complimentary with ECU Upgrades
Continuar a ler...
