não é por nada mas acho que aquele motor vai ter um pouco de LAG
Behold the world's first C30 RWD conversion.
http://www.skruffse.se/
Engine
Volvo B5244T with CrMo lining
Turbonetics T80
Dry sump
Modified head
Fueled with E85
Managed by MoTeC M800
Drivetrain
Sellholm MPG 5-speed sequential gearbox
3-plate Tilton clutch
ZF rear differential assembly with custom rear subframe
Custom bellhousing
Suspension
Öhlins 2-way shocks
Volvo S60 front suspension components used in rear
Volvo 240 front suspension components used up front
Brakes
Porsche GT2 calipers in front 6-pistons and 378mm discs
Volvo R-calipers in rear with 335mm discs
Homemade adapters
Wheels
Dotz Roadster wheels
20x9 front P245/30R20
20x11 rear P305/25R20
Rear wheels custom modified from original 10" width to 11"
http://www.speedparts.se/php/g...=3331
Note: pics may show some older parts like KW coilovers and Holset turbo
T40 Stage 1 complete, lets go to the Stage 2
