1. Applications:
VAG5053 is a powerful, affordable handy scanner designed for all VW, AUDI, SKODA, and SEAT vehicles. It is small in size, robust in design, competitive in price and easy to use. With only 10% of the cost of a large special tool, it can nearly do the same work as that of a VAG1551/1552. This is a stand alone unit; it does not need a laptop computer to operate.
2. Available Functions:
Control Unit Information
Read Fault Codes
Measuring Blocks
Clear Fault Codes
Basic Setting
Adaptation
Single Reading
Output Tests
Code Module
Login
Service Oil Reset
Code Modes
Dealership Code Set
3. Supported Systems:
VAG5053 can support the following systems:
Engine
Transmission
Airbag, etc.
there are 78 systems available.
160 euros
0-100 4S 0-400M 12S
http://xpower.blogs.sapo.pt/
