Resultados 1 a 2 de 2
Tópico: Vendo Sub. Diamond D312D2 e Amp. JBL GTO601.1
    Mar 2007
    16
    Padrão Vendo Sub. Diamond D312D2 e Amp. JBL GTO601.1
    Boas.
    Bem aqui estou eu a vender os meus bens..vendi o carro e agora o que comprei já tem um bom som e claro os € andam a fazer falta..
    Estão aqui as imagens do Amp. e do Sub.
    http://img19.imageshack.us/gal.php?g=imagem128copy.jpg
    Especificações:
    Amp. JBL GTO601.1
    Performance
    RMS Power Output (Watts x Channels) 424 x 1
    Peak Power Output (Watts x Channels) N/A
    Power at 2 Ohms (Watts x Channels) 580 x 1
    Bridged Power (Watts x Channels) N/A
    Minimum Impedance Bridged N/A
    Minimum Impedance Unbridged 2
    Best Frequency Response 10-302Hz Hz
    THD at Rated RMS Power 1%
    Signal to Noise Ratio 72 dB
    Input Voltage 14.4v
    Features
    Amplifier Class D
    Low-Pass Crossover Frequency 32-320 Hz
    Low-Pass Slope (dB/octave) 12 dB
    High-Pass Crossover Frequency N/A
    High-Pass Slope (dB/octave) N/A
    Bass Boost 0-12 dB
    Bass Boost Frequency 50 Hz
    Fan Cooled No
    Fuse Rating 30 x 2
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    LED Power Indicator Yes
    Width (inches) 15-7/8
    Height (inches) 2-3/8
    Depth (inches) 12-3/8
    Diamond D312D2
    Subwoofer Specifications
    Subwoofer Size 12"
    Voice Coil(s) Dual (2 voice coils)
    Impedance (per voice coil) 2 ohms
    Peak Power Handling 800 watts
    RMS Power Handling 400 watts
    Woofer Composition Textured copolymer
    Woofer Surround Foam
    Sealed Box Volume 1.5 cu. ft.
    Ported Box Volume 2.0 cu. ft.
    Sensitivity 86 dB
    Frequency Response 25 - 250 Hz
    Xmax (millimeters) N/A
    Top Mount Depth 6.2"
    Cutout Diameter 11.1"
    Preços:
    Amp. 160€
    Sub C\Caixa: 150€
    O Conjunto: 270€
    Entrego em mão em Lisboa ou arredores.
    Obrigado e qualquer questão digam. :fixe:
    Mar 2007
    16
    UP!!
  1. Vendo Sub. Diamond D312D2 e Amp. JBL GTO601.1
    Por thekiller no fórum Car Audio & ICE
    Respostas: 8
    Última Resp.: 23-02-2011, 13:47
  2. [Vendo] HTC DIAMOND
    Por webito no fórum outros
    Respostas: 6
    Última Resp.: 13-01-2009, 21:23
  3. vendo sub diamond
    Por jmpp no fórum Peças e acessórios
    Última Resp.: 16-05-2007, 21:07
