Quase novo a funcionar impecavelmente posso enviar mais fotos...
~ 160 Watts Max. Music Power (Mono) (80W Nominal)
~ Frequency Response: 35-300Hz
~ Sensitivity: 103dB (1W/1m) (In Car, SUV Type)
~ RCA Preamp Inputs
~ RCA Preamp Inputs
~ Speaker level Inputs
~ Input Level Control
~ Variable LPF Crossover (50-125Hz, -12dB/Oct.)
~ Max. Current Consumption: 17 amps
~ IMPP - Injection Molded Polypropylene Composite Cone Woofer
~ High Compliance Rolled Urethane Surround
~ Conex Damper
~ Glass-Imide Voice Coil Bobbin
~ Convex Dust Cap (w / SL Logo)
~ High Performance Strontium Magnet
~ Sub Size: 8"
~ Magnet Wt.: 18 oz.
~ 13 Liter
Specifications:
~ Bass-Reflex Design Enclosure
~ C-Cut Design 5/8" Thick Wood Enclosure for Richer Bass Reproduction
~ Black Carpeting
~ Front-Loaded Woofer with Rear Port for Optimum Bass Response
~ Parallel connection capabilities for Double SPL
~ Woofer Grille (Black) with Round-Punched Metal Screen and Resin Surround (Titanium Gray)
~ Top Mounting Brackets and Mounting Belts/Plates
~ 4 Ohm Rated
Última edição por skelt; 27-08-2015 às 20:48.
