ZXti600 SPECIFICATIONS:
Output Power:
4 ohm stereo @ 12/13.8 VDC
75/150 WRMS x 2
2 ohm stereo @ 13.8 VDC
300 WRMS x 2
4 ohm bridged @ 13.8 VDC
600 WRMS x 1
Crossover Frequencies
40Hz to 800Hz
Crossover Slopes
24dB per Octave
Frequency Response
+/-1dB from 20Hz to 20kHz
Signal to Noise Ratio
>100dB
Input Sensitivity
200 millivolts to 2 volts
Input Impedance
>10k ohms
Bass EQ
0 to + 12dB @ 45Hz
Input Voltage Range
10.5 volts to 15.0 volts
Typical current draw at idle
750 milliamps
Minimum Impedance
2 ohm bridged/1ohm stereo
Dimensions, ZXti400
11.75"L x 9.8"W x 2.25"H
Dimensions, ZXti450, ZXti600
