Product Description.These are OEM Acura injectors that come stock on the Acura RDX. These injectors are ideal for modified all motor K-Series engines using performance parts such as cams, intake, Kpro, header, throttle body or intake manifold.
Special high-flow fuel injectors with a wide dynamic range contribute to the RDX's low emissions and high horsepower, and a variable-flow fuel system also contributes to low evaporative emissions. The accuracy of the control of the injector has been increased so that less fuel can be injected during certain situations (such as idle).
