Resultados 1 a 3 de 3
Tópico: VENDO Injectores 325cc 415cc etc novos
    Senior Member Super user Avatar de bakuuu
    Aug 2005
    Viana do Castelo/Porto
    1.030
    Talking VENDO Injectores 325cc 415cc etc novos
    Tenho para venda injectores da BOSCH:
    Bosch grey 325cc/minute@4bar (282 cc/min@3bar)injector, new style (slightly shorter than the usual: 52mm between O-rings center to center), all plastic, compatible with old style, 16ohm. Factory injectors in VAG (VW, Audi) 1.8T (20 valve 4 cyl turbo) engines.
    Bosch 0 280 156 070 = VAG 06B 133 551N
    PREÇO(NOVOS) de 4 INJECTORES: 200euros
    Bosch high-impedance (12.6ohm) injector.
    Specified as 391cc@3.8bar with test fluid. Approximate flow with gasoline= 415cc/minute@4bar. New style, all plastic, fully compatible with old style (actually grey color,used in Volvo, Bosch 0 280 155 830)
    PREÇO(NOVOS) de 4 INJECTORES: 298euros
    Siemens high-impedance (12.6ohm) injector.
    L107 Siemens / Mototron Deka 4 (Flow-Matched sets to 1%)
    other names: Siemens FI114961 - Mototron INJ-GAS-006 - Accel 74620L - MSD/Edge 2030
    Static Flow Rate at different fuel pressures:
    60lb/hr (sometimes called 63 lb/hr). For estimations: with BSFC=0.5lb/(HP*hr) this means 120 HP/cylinder at 100% duty. You want to apply your estimated BSFC, max duty and add some margin. Also note that BSFC is higher with Ethanol based fuels like E85.
    630cc/min @ 3bar (=300kPa = 43.5 psi)
    727cc/min @ 4bar (=400kPa= 58 psi)
    PREÇO(NOVOS) de 4 injectores: 360euros
    Injectores á homem lol:
    Bosch 1580cc/min at (3bar) mid-impedance (appr 5.6 Ohm) injectors
    +15% (= 1824 cc/min) with 4bar fuel pressure.
    Genuine Bosch 0 280 150 842 injectors. Probably the highest flow injectors around. Bosch 1580cc Top Feed Injector. They are claimed to be exactly the same injectors as Indy Blue's. Can be used for alcohol (or E85) or gasoline.
    PREÇO: 420euros
    qq coisa 963168018
    uuukab@msn.com
    Mini One D 2006
    Range Rover V8 1992
    Dec 2005
    alfragide
    63
    Citação Mensagem Original de bakuuu Ver Post
    PREÇO: 420euros
    qq coisa 963168018
    uuukab@msn.com
    e uns bosch 0 280 150 984 arranjas???
    Aug 2005
    1.030
    n amigo só os que aqui estao.vou tentar informar me se arranjar eu aviso.
    Mini One D 2006
    Range Rover V8 1992
  1. [Vendo / Troco] Injectores PD 150 ARL com FB783 novos
    Por _redliner_ no fórum Peças e acessórios
    Respostas: 11
    Última Resp.: 06-10-2011, 05:15
  2. Vendo bicos de injectores 520 race novos
    Por hmcp no fórum Peças e acessórios
    Última Resp.: 16-08-2010, 06:09
  3. Novos injectores
    Por jcssvcd77 no fórum Tuning Motor Diesel
    Respostas: 4
    Última Resp.: 09-01-1970, 14:23
