Boas pessoal...
Como vou vender a minha argolas e o meu sistema multimédia não dá no novo carro vou vender o sistema todo...
É composto por
Além de gps tem montes de funcionalidades que só mesmo lendo o manual é que se consegue ter noção...
Aqui ficam alguns dados relativamente à parte do rádio/leitor de dvd/mp3/Cd/outros, e monitor/TV
PRODUCT FEATURES:
6.5 inch Wide Color TFT Active Matrix Display;
Number of Pixel: 336, 960 pixels;
Screen Size: W143, 6mm x H77.1mm;
Fully Motorized Slide-Down Mechanism;
Motorized Tilt Angle Adjust (6 Step);
Interactive Touch Panel Control with OSD (On Screen Display);
Multifunction Key Operation;
DVD Disc Menu Direct Touch Operation (Highlight Control Mode);
Audio Easy Control Mode;
Security Code Function & Security Indicator;
Selectable Key Illumination (Green/Red);
New Amplifier Control System with '04 PS Amplifiers;
Advanced B.M.S.(Bass Management System) with '02 PS Amplifiers;
Wired remote out for original mounted steering wheel remote control;
iPod connection with optional interface KCA-iP500;
2-way Telephone/Navigation Mute;
TV reception with optional TV Tuner KTC-V500E;
Digital Clock (24H);
Remote Control Unit Supplied.
Faz bastantes coisas... Posso dizer que eu não explorei sequer 50% das potencialidades dele...
Isto aliado ao sistema de GPS que tem as seguintes funções
Easy-to-Use graphical interface
3-dimentional or 2-dimentional map display
Adjustable 3-D map view angle
13-step map display scale
Selectable visual guidance modes (full map/split map w/turn list or w/arrow)
One-touch scroll speed
On-route scroll
Hi-Speed Scrolling (Jump to start point, play toward starting point, pause, play toward destination, jump to destination, category select)
Voice recognition control with optional Kit KVA-VC300 (7 languages: English US, English UK, German, Dutch, French, Italian, Spanish)
Voice guidance (female / 12 languages: English US, English UK, German, French, Dutch, Italian, Spanish, Portuguese, Danish, Swedish, Norwegian and Finnish)
Turn-by-turn instructions via voice prompt
Hi-speed auto re-route (less than 2 seconds)
Detour re-routing
Route preference function
3 route variations (min. time, min. distance, other)
Setting up of search conditions (quick/short/normal) is possible at each way point)
Multi search mode :
- address, P.O.I., categorized memory points
- preset/ previous destination, freeway exit/entrance, intersection search)
Highway mode screen (exit mark, facility display indicator, forward scroll, backward scroll, distance to the car, current position)
Destination search mode (address entry, POI, memory points, postcode, latitude/longitude, intersection landmark)
RDS-TMC, dynamic route guidance, with optional unit
KNA-TM320 (auto country select, events list, events voice guidance)
Remote controllable with optional unit KNA-RC300
46 icons + 6 icons with audio (including 2 with user definable directions for speed camera’s)
4 memory points categorization (personal, entertainment, business, marked point)
100 previous destinations memories points
Quick, short or normal settings between way points
PERFORMANCE FEATURES
Piezo-electronic vibrating gyroscope
Wheel rotation speed pulse sensor
Vehicle position sensing (GPS/gyro/speed pulse)
Map matching position comparison
SDRAM memory (32MB)
GPS features
GPS receiver (8-Channel)
Position updating (2 calculations/sec)
Screen updating (once every second)
CONNECTION FEATURES
Audio/video output (NTSC)
Speaker output
Remote control input
RGB/touch screen input
RS-422 interface to connect TMC Tuner KNA-TM320
Micro strip plane antenna
Resumindo é um sistema do mais completo que há...
Preço 1000 euros
