boas
tenho vario material de diagnostico para venda
cabos diagnostico grupo vag
cabos diagnostico para mercedes
cabos diagnostico para bmw
cabos vag kkl usb 409
30 euros
cabo vag can bus 704 ( funciona no windows vista )
75 euros
Name: BMW Scanner 1.25
Information Features:
It’s working with BMW Scanner 1.2.5 software from PA-Soft to read/clear error codes and read/write certain memories of devices in the diagnostic chain!
The software of BMW 1.2.5 can be provided free of charge by email.
Main Functions:
Read/Write EEPROM
Odometer Correct
Load/Save EEPROM
Clear Errors
Reset Unit
Copy Coding
Other Functions
Package:
BMW Scanner Interface
OBD2 connection cable
BMW connection cable
Measurements:
G.W.: 0.65Kg
Standard Export Carton Box
Car Lists:
BMW scanner interface,works on E38,E39,E46,E53...
BMW Scanner version1.2.4 from pa-software.
You can reset service lights,Read and clear error codes,Write or rewrite memories.
Can be used on BMW 3,5,7 series and X5.
Included in the package are the scanner interface,
Pa-software,OBD connector and BMW round connector.
150€
Opel Tech-USB
USB Interface for the 3rd party Opel TECH2 Software with K-Line Multiplexer which does not require switching of diagnostic pins
Package Contains
- USB TECH2 Interface
- USB extension cable
USB Interface for TECH2 Software
100€
tenho tambem carsoft 7.4 completo para mercedes 150€
kits xenon em 6000k e 8000k
125€
entrego em mão na zona de odivelas
envio ctt registado
envio a cobrança
