pm´s enviadas...
Tal como o titulo indica tenho á venda o meu sub com muita pena minha....
A qualidade do mesmo dispensa comentários....
Está fora de questão a montagem do som que tinha no actual carro ainda para mais com mais uma pirralha na familia....
Preço : 150€
"Boston USA - "When we were testing the prototypes for the new ProSeries subs, they actually handled more power than our most powerful test amps could dish out. In fact, one amp gave out before the Pro Subs ever broke a sweat (May it rest in peace). How did we accomplish that? Pure engineering. Pro Subs handle a lot of power, because weve worked out new, innovative ways to keep them cool. Like using die-cast aluminum baskets that act as massive heat sinks. Or by employing a pretty sophisticated (and patented) venting technology called RadialVent Cooling. Then we engineered ProSeries to deliver in the SPL department. High mass cones and pliant surrounds deliver lots of incredible, tight bass even at high volumes. And a double-stacked magnet motor assembly concentrates energy where it can do the most good. Finally, we optimized ProSeries subs incredible output from small enclosures, so you can put more subs in an equal amount of space. The result: the cleanest, loudest sub youll hear in your lifetime."
Product Details:
Key Features:
Car Speaker Type Component
Elements 1-Way
Function Subwoofer
Size 12"
Nominal Power Handling 50 Watt
Powered Non-Powered
Technical Features:
Peak Power Handling 1200 Watt
Impedance 2 ohm (Dual Coil)
Mounting:
Enclosure Non-Enclosed
Top Mounting Depth 5.63 In.
Mounting Diameter / Length 11 In.
Última edição por velocity; 14-04-2012 às 18:45.
pm´s enviadas...
Upa para o som de qualidade....
Não se arrependerão do dinheiro investido neste sub..
Continua á venda
Baixa de preço -> 125€
Ninguém um Sub de grande qualidade e fiabilidade????
Preço -> 120€
