uppppppppppp
Boas tenho para venda este Rádio,
Radio Kenwood KDC-W5037, tenho factura e garantia de 18 meses ainda
custou 170€ estou a pedir 60€ por ele ( negociaveis mas pouco ).
Stunning design featuring a flip-down faceplate and a large display, KDC-W5137Y offers high sound quality playback of compressed music thanks to advanced technology and 24bit D/A converter. Moreover, you can hook up your MP3 player through the Aux Input terminal on the rear.
Key Features
Flip-Down Full Detachable Faceplate
50w x 4, Max Output Power
Mini-jack AUX input, 1 RCA preout
Changer Control
MP3/WMA/AAC Decoder Built-in
General Features
DIN Size 1 DIN
Detachable Faceplate Yes
Protection Case For Faceplate Yes, Soft Case
Faceplate Mechanism Flip-down Detachable Faceplate
Angle Adjustment No
Disabled System Indicator (DSI) Yes
Security Code Function Yes
Rotary Encoder & Control Knob Yes
Operation mode 4-Directions + Push
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
IR Remote control RC-557 Included
Digital Clock (24H) Yes
All-off Select (20/40/60 minutes) Yes
Built-in Connector Molex 16 pin
ISO connector Yes, Molex to ISO cable
Display Features
Display Type Flourescent (FL) Tube Display
Display Layout 14 segments x 8 Characters
Dimmer Control 2 steps - Manual
Display Off Mode Yes
Demo Mode Yes
Special Character Display Russian Characters
Tuner Features
RDS (PI, PS, AF, TI, Clock) Yes
Radio Text (RDS) Yes
Programme Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
CD Features
CD-R/RW Compatible Yes
MP3 Playback with ID3 Tag Display Yes
WMA (Windows Media Audio) Playback Yes
AAC (Advanced Audio Coding) Playback Yes
CD Text Support Yes
CD Text with special Character Support No
Supreme Yes
D.A.C. processing 24 bit (built-in)
0 bit Mute Yes
Random Function (Track/Disc) Yes
Repeat Function (Track/Disc) Yes
Scan Function (Track/Disc) Yes
External Media Control Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Audio Features
Maximum Output Power 50W x 4
Auxiliary input Yes, Rear
Auxiliary Type Mini-jack Built-in
Pre-out 1 RCA
Pre-out Output Level 2V
Preout Rear / Subwoofer Switchable Yes
Subwoofer Reference Level Adj. Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader/Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System Q (Preset Sound Control) Yes
Bass Boost Circuit Yes
Low-pass Filter Yes
Connectivity
Changer Control (5L-Bus) Yes
AUX input (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
Bluetooth Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) No
2-way Telephone Mute Wire Yes
Cosmetics features
Front/edge Black Injection
Dress plate Dark Silver
Volume & operation knob or wheel Chrome Plated
Preset key finish Black Injection
Escution Black Injection
Key illumination Red or Green (selectable)
Volume & operation knob illumination Blue
Triangle Illumination Red
Tuner Specifications
FM Frequency Range 87.5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0.7μV/75ohm (S/N 26dB)
FM Quieting Sensitivity 1.6μV/75ohm (S/N 46dB)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Sigal to Noise Ratio 65dB(MONO)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz
MW Frequency step 9kHz
MW Usable Sensitivity 25μV (S/N 20dB)
LW Frequency Range 153kHz ~ 281kHz
LW Usable Sensitivity 45μV (S/N 20dB)
CD Specifications
Laser Diode GaAIAs
Digital Filter(D/A) 8 Times OverSampling
Digital/Analogue Converter 1 Bit
Spindle Speed 500 ~ 200rpm (CLV: 1 times)
Wow & Flutter Below Measurable Limit
Frequency Response 10Hz ~ 20kHz (±1dB)
Total Harmonic Distortion 0.01% (1kHz)
Sigal to Noise Ratio 105dB (1kHz)
Dynamic Range 93dB
MP3 Decoder Compliant with MPEG-1/2 Audio Layer-3
WMA Decoder Compliant with Windows Media Audio
AAC Decoder AAC-LC".m4a" Files
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 2000mV / 10kOhm,
Preout Impedance 600Ohm
Speaker Impedance 4Ohm ~ 8Ohm
AUX Frequency Response 20Hz ~ 20kHz (±1dB)
AUX Maximum Input Voltage 1200mV
AUX Input Impedance 100kOhm
Bass Tone Control 100Hz ±8dB
Middle Tone Control 1kHz ±8dB
Treble Tone Control 10kHz ±8dB
Mais Info -> cmcsantos@gmail.com ou 913602652
Última edição por NoFear; 26-12-2007 às 05:37.
uppppppppppp
Se puderes baixares isso para os 50, fico te com isso.
Vou buscar em maos , se fores da zona de lisboa...
Boas vendas...
boas, ficoo com o radio mm por 60€... e pago os gastos de envio se nao fores da zona do porto.
esse radio ainda tá á venda????
ainda tens o radio para venda ????
aceitas trocas??
se sim, envia PM
