Radio em excelente estado!
com comando, manual, etc etc
sergio.chaves@sapo.pt
936900394
specs:
Power supply 12V DC(11V-16V)
Test voltage 14.4V, negative ground
Maximum power output 55Wx4 channels
Continuous power output 25Wx4 channels (4 10% T.H.D.)
Suitable speaker impedance 4-8 ohm
Pre-Amp output voltage 2.0V(CD play mode: 1KHz, 0 dB,
10K load)
Fuse 15A
Dimensions(WxHxD) 178x50x166mm
Weight 2.2kg
Sub-out 2.0V
Aux-in level 300 mV
3 INCH TFT LCD
Display vesolution(dot) 960(W) x 240(H)
Active area(mm) 60.00 x 45.00
Screen size(inch) 3.0(Diagonal)
Dot pitch(mm) 0.0625 x 0.1875
Contrast ratio 300
Brightness 350 nits
FM Stereo Radio
Frequency range 87.5-108.0 MHz (Europe)
87.5-107.9 MHz (America)
Usable sensitivity 8 dBμ
Frequency response 30 Hz-15KHz
Stereo separation 30dB(1 KHz)
Image response ratio 50dB
IF response ratio 70dB
Signal/noise ratio >55dB
AM(MW) Radio
Frequency range 522-1620 K Hz(Europe)
530-1710 K Hz (America)
Usable sensitivity(S/N=20dB) 30 dBμ
Disc Player
System Disc digital audio system
Frequency response 20 Hz - 20 KHz
Signal/noise ratio >80 dB
Total harmonic distortion Less than 0.20%(1 KHz)
Channel separation >60dB
Video signal format system PAL/NTSC/AUTO
Video
video output 1 0.2V
horizontal nesowtiou 500 lines
Components
Mounting collar 1
Machine screws M5x6 mm 4
M4x6 mm 4
Mounting bolt (50 mm) 1
Wire connector 1
Removable face plate case 1
Trim plate 1
T-key 2
Operating Instructions 1
Rubber cushion 1
Remote control 1
