ainda tem o radio para venda?
estou interessado....
poderia responder para josefonseca86@sapo.pt
Vendo auto radio Kenwood KDC-W6027, está como novo.
Deixo aqui as especificações do radio.
40€
Kenwood KDC-W6027 CD receiver key features
Compatible with MP3 and WMA format discs as well as conventional audio CDs
Removable flip down front panel with switchable face-removed LED warning and security code
Colour 12 segment dot matrix display with contrast adjustment and dimmer
Rotary volume control. Red or green (switchable) button illumination
Radio can be connected to factory-fitted remote controls and external dashboard displays on most cars (adaptor required)
Compatible with current model Kenwood CD / MP3 changers
Accepts auxiliary input lead to connect iPod, walkman etc.
Infra-red remote controller can be added as an accessory
CD-R / CD-RW compatible
Display of CD text information from head unit or compatible CD changer. Display scrolls if necessary
Disc Name Preset allows names to be assigned to discs in optional CD changer. When disc is selected the name will appear on the radio's display
Disc Name Preset Play allows you to select by name any disc in optional CD changer. (Optional hand-held remote control is required)
RDS (radio data system) & EON (extended other networks) tuner
DAB tuner can be added as an option for Digital Audio Broadcasting reception
Full coverage of LW / MW / FM wavebands
Display of radio text information
4 x 50 Watts max power (MOSFET)
System Q sound control
System E's light provides high-pass filter and 5 step low-pass filter for improved control of sub speaker
BMS external amplifier control
0-bit muting for silence between tracks
Two RCA preout (2.0 volt) for connecting external amplifier (rear non-fade switchable)
Display auto-dims when vehicle's side lights turned on
24 hour clock display
Two way telephone mute
Automatic turn off (after selectable delay of 20, 40 or 60 minutes)
Entrego em mão na margem sul, zona Barreiro.
Última edição por alexcoupe; 31-10-2011 às 12:44.
