Boas!! Tal como o tópico indica... Tenho para venda um DLS de 3 canais - CA 31
Este amplificador seria para ser montado no Celica do meu irmão. Entretanto, tal não aconteceu...
O amplificador está NOVO, apenas foi testado. No entanto podem ver o seu estado pessoalmente, sem compromisso.
Product Features
* RMS output per channel at 13,8 volts
* Mode : AB
* Number of channels : 3
* Power output in 4 ohm (0,1% THD) : 2 x 65 W
* Power output in 2 ohm (0,2% THD) : 2 x 90 W
* Power output mono channel in 4 ohm : 170 W
* Power output mono channel in 2 ohm : 280 W
* Frequency range : 10 Hz - 35 kHz
* S / N-ratio, A-weighted : > 100 dB
* Damping factor : > 100
* Input impedance low level : > 10 kohm
* Input impedance, high level : 100 ohm
* Input sensitivity, variable : 0,25 - 5 V
* High level input with auto start : Yes
* Low level output : No
* Filter channel A & B : Highpass: 50-150 Hz.
* Filter channel C : Lowpass: 50 - 120 Hz + subsonic 25 Hz
* Phase control 0 - 180 degrees : Yes
* Current draw, idle : 1,0 A
* Fuse value : 2 x 30 A
* Dimensions H x D x B : 67 x 340 x 250 mm (2,63 x 13,38 x 9,84 inch)
Product Description
Classic series CA31 The new Classic CA 31 is a three channel amplifier with a nominal output of 2 x 65 Watts + 1 x 170 Watts (1 x 280 Watts in 2 ohm). Built-in high-pass, low-pass and subsonic filters. Variable phase control on sub channel. High level input. Protection circuits shut down the amplifier in the event of overloads. The perfect amplifier for a standard installation with a front system in stereo and a subwoofer in the back. High level input with auto start.
Preço:
150 euros - Valor Fixo
