Boas ppl,
como indica o topico tenho 1 amp destes para venda.
aqui vai as specs:
MAC Audio MPX2000 500W 2 Canais
Especificações:
Max. power output* into 4 Ω2x180/ 1x500 WattRMS power output** into 4 Ω2x60/ 1x150 WattMax. power output* into 2 Ω2x250 WattRMS power output** into 2 Ω2x80 WattFrequency response5 – 50 kHz (-3 dB)THD< 0,05 % (1 kHz)Signal-to-noise ratio> 100 dBInput sensitivity0,4 – 4 VDimensions (W x L x D)239 x 59 x 226 mmInput impedance20 kOhmPower impedance12 V minus an MasseWeight1,9 kgHighlights
2 ohm stable
Variable low pass 40 – 300 Hz (12 dB per octave)
Variable high pass 40 – 300 Hz (12 dB per octave)
Variable bass boost 0...12 dB at 45 Hz
Bridge- / Tri-mode capability
Protection circuit that safeguards against short circuits, DC-offset and overheating
Green operation and red protection indication LED
* (Sinus Burst 2:8, 1 kHz) 14,4 V
**(DIN 45 324) 14,4 V
Como novo!!
preço: 50€
localidade: Lisboa
email:mantleytrance@gmail.com
tlm:96 6519808
VW Bora 1.6 Highline
