Boas, es de onde? Tambem fazes montagens de alarmes? Se o fizeres posso ficar com um!!
Tenho estes produtos para vender, proveniente de 1 group-buy no Ebay.
O material é NOVO , em CAIXA, apenas removidos das caixas para as respectivas fotos para interessados.
Alarme Bulldog:
Specs:
The Bulldog Pro Series 5002 PRO alarm by JBS/Bulldog Technologies is a technological breakthrough utilizing the most advanced, state-of-the-art technology and components.
The 5002 PRO features two four button extended range compact remote transmitters.
Two onboard relays are provided to work with any vehicle's door locks without additional parts.
The trunk release will remotely open your trunk with the push of a button.
An instant personal panic protection feature will ward off any would be thieves or attackers by sounding the siren and flashing lights while inside or outside the car even if the motor is running.
A starter immobilizer prevents the car from being started when the system is armed.
The distracted entry function will automatically rearm the system if you disarm it and get distracted before entering the vehicle.
When disarming the vehicle the interior lights will come on so you never have to walk up to a dark car again.
Use the active arming feature to arm the system via your remote or use the passive arming feature to allow the vehicle to automatically arm itself one minute after the door is closed.
The 6 tone 126dB siren attracts more attention by changing its tone every 6 seconds
Features:
Remote keyless entry
Dome light supervision
Remote car finder
Dedicated instant panic protection
Two negative outputs
Output for starter immobilizer; plug in override switch
Parking light confirmation with onboard relay
Plug in led.
126db six tone siren
Remote programmable current sensing
Remote programmable passive arming
Remote control sensor bypassing
Distracted entry
Auxiliary output
Door trigger protection
Preço: 65 euros
Alarme Fusion:
2 x 3 Button Remotes
Dual Stage Shock Sensor and Engine Disable
Remote Car Finder and Optimal Sensor Port
6 Tone 123dB Siren and Silent Arming Capable
Onboard Central Locking and Park Light Relays
5 Digit Override Code
Automatic Zone Bypass
LED Status Indicator
preço: 75 euros
Alarme: Commando 520
Full Feature Security System with built in relay for Parking Light Flash, 1 Aux output, Lock / Unlock Outputs, Dual Stage Shock Sensor, 6 Tone Siren, Multi Sensor Input, Start Disable, Two - 3 button Remotes and MORE!
Features
Two Sleek 3 Button Multi-Channel Transmitters
Audible & Visual Arm/Disarm And Intrusion Alert
Code learning Receiver
Anti-Scan Technology
Remote Keyless Entry (Negative Output)
Remote Auxiliary Channel For Trunk Release
Power Window Control, Etc.
User Selectable Silent Arm/Disarm
Remote Sensor Defeat
Dual Stage Electronic Shock Sensor (Plug-In)
Alarm Pre-Warning Signal
Defective Zone Bypass With Warning
Remote Panic
Starter-Disable Protection
On-Board Flashing Parking Lights Relay
Plug-In LED Status Indicator
Plug-In Protected Valet/Override Switch
6-Tone, High Power Siren
Programmable Passive/Active Arming
Programmable Door Lock With Passive Arming
Programmable Autolock/Unlock Through Vehicle's Ignition
Qualifies For Insurance Discounts
One Year Warranty
Complete Owners Manual
Complete Installation Manual
Toll FREE Tech Support Line
E-mail Tech Support
Preço: 135 euros
sou do porto ,nao faço montagem mas arramjo quem te o monte
