Vendo turbo Igual ao da foto. Está praticamente novo andou 200km.
Specs:
-Compressor A/R=0.86
-T25 Flange
-Internal wastegate with 8psi actuator
-Max Power: 375hp, 25-27psi, spool time at 2500RPM
-Compressor outlet pipe 50mm, inlet pipe 50mm 2 bolt flange, 48-trim compressor, intrducer 37.8mm, exducer 59.7mm -Turbo wheel Ind. 52.9mm, Exd. 45-47mm
http://img707.imageshack.us/img707/4...7fnlqkbozz.jpg
185€ Negociaveis para despachar.
Contactar : 968902982 / 914929642 - shot.ribeiro@gmail.com
