Nem sei o que se trata mas a primeira vista e pelo face do site é mais dakelas cenas que interessa é vender mesmo que não sirva para nada..
boas
numa das minhas pesquisas aki pela net fui parar a este site:
http://www.surbo.net/
apos visitar akilo,pus me la a ler a treta americana,e akele discurso deles em k tudo é uma maravilha e so tem vantagens e tal...decidi mandar lhes um mail,k deixo abaixo,tal como a respectiva resposta da parte da empresa:
Hello
Thanks for your enquiry. The Surbo will increase the air flow rate, and by
our airtight installation, result in complete delivery of the air pressure
to the engine's manifold, thus resulting in higher compression in the
cylinders, leading to an increase in torque and power. The added energy
means that you can travel faster or save fuel by pressing less than normal
on the accelerator, or a bit of both. Normally customers achieve an
improvement in economy of 10%. The Surbo requires 6 inches of air intake
space, and costs 59 usd via air parcel.
Guided DIY installation. You can pay via Paypal.
If you desire more power, you might try the Twin Surbo, which provides 10%
more torque than the single Surbo between 2500-3000 rpm, and if you drive in
this middle rpm range most of the time, this will result in even more
economy, about 15% based on customer feedback. This requires 11 inches of
straight air intake space. It will cost 99 usd.
Both the Surbo and Twin can be fitted on the inlet to the original filter
(of the carb Civic 87-91). I do not know if your model is the same
(unlikely) so to proceed please send a low resolution pic of the air intake
so I can prescribe a solution.
Generally, the Surbo or Twin Surbo will give better acceleration,
hill-climbing, overtaking and higher top speeds, and easier cruising since
the cruising speed is proportional to top speed. For MANUAL cars, the driver
will be able to reach the red line on the rpm meter with just half throttle.
For AUTOMATICS, there will be instant takeoff from standstill without any
delay as before, ability to change gears below 3000 rpm for economy or to
rev past that for better pickup. For DIESELS, there will be less black smoke
and better revving, pulling power and load carrying ability.
Our products have a lifetime warranty, and they are transferable to your
future vehicles as the Surbo fits most cars easily.
----- Original Message -----
To: <surbo>
Sent: Wednesday, November 29, 2006 2:13 AM
Subject: WWW Form Submission
> Below is the result of your feedback form. It was submitted by
> Jose Leal (zt_leal@hotmail.com) on Wednesday, November 29, 2006 at
02:13:10
> other email: zt_leal@clix.pt
> country: Portugal
> city: Porto
> Make: Honda
> Model: Civic
> gearbox: Manual
> Fuel: Petrol
> Yr: 1994
> cc: 1300cc
> type: carb
> Air pipe: original
> Air pipe mods:
> Filter box: original
> Filter box mods:
> Air filter: original
> Other mods:
> Found:: Internet search
> string:: Webber carburator
> consumption:: 0,8lts/10km
> Wants/ Problems: I want to know if is possible to apply a Surbo in my
car, and how it will costs?
> (sorry my english)
o k voces axam disto?
Opel Corsa C - Convertido aos fumarentos
Mensagem Original de Helopez
O que ele disse certo
345hp/390lb......189Mph....alguem quer brincar?
Não funciona... nada substitui o turbo ou compressor...
Forte abraço
surbo so o nome... dá pra um gaijo rir loooooooooooooooooooooooooooooool
a minha opniao e a mesma do resto do pessoal nada substitui um bom e GRANDE turbo lol
Isso é muito bom...
Pena que os ganhos sejam quase nulos, porque o alivio de peso na carteira, é comensado pela adição de peso ao carro. Como o surbo pesa mais do que as notas que sairam da carteira, a relação peso potencia fica afectada.
:P
