Ui.. Belo :O~~
006 Gallardo SE special edition. There were only 250 of these made, and only 4 made with e-gear in Verde from what I am told. The car has well over $100,000 in modifications and $30,000 paint on top of the price of the actual car. This car has been 100% done by Heffner Performance in Sarasota Florida. For those of you who know modified Lamborghini's, Heffner is the class of the industry. The engine has been entirely removed and built bulletproof.
This vehicle makes over 1300awhp on race gas, 1016awhp on 100 octane pump gas. Now remember, this is WHEEL horsepower. You can also go back to a pump gas set up where the car makes 880awhp. The great thing about this car is that it retains all driveability. It drives just like stock until you get into the boost.
Mods.............
Engine Removal and Disassembly -
L.A. Sleeve Steel Cylinder Liners -
Carrillo Forged Rods -
Custom 9:1 CP Forged Pistons -
Polished Crank Journals -
Clevite bearings -
Balancing and Blueprinting of Engine -
Heavy Duty Clutch and Pressure Plate -
Twin Water Cooled Dual Ball Bearing Garrett 67mm Billet Wheel Turbos -
T04 S compressor w/72mm inducer
Garrett T4 four bolt discharge housings w/82 A/R ratio -
Two Tial 44mm wastegates -
Two Tial 50mm Blow Off Valves -
Custom Made Stainless Steel Turbo Midpipes -
Custom Made Stainless Steel Turbo Downpipes -
Custom Made Stainless Steel Exhaust System -
Stainless Steel Turbo Oil Feed Lines -
Stainless Steel Turbo Oil Drain Lines -
Colder Heat Range Spark Plugs -
High Flow Turbo Air Inlet Plumbing -
High Flow Turbo Air Discharge Plumbing -
Spearco twin Water to Air Intercoolers -
Water Pump -
Intercooler Water Reservoir -
All Braided Lines and Fittings -
255 lph in tank fuel pumps -
Upgraded Fuel Injectors -
K&N conical air filters -
Upgraded Gaskets and Fluids -
Upgraded Halfshafts -
AEM EMS -
Dual Maps controlled by switch -
Genuine Lamborghini OEM Superleggera Carbon Rear Diffuser -
Carbon Decklid -
Larger Brembo Rotors -
Full Body Clear Bra by Pro-Tech (over $5000) -
15% tinted windows -
Ceramic windshield covering -
K40 Calibre In Car Laser/Radar -
HRE 843R w/Textured Monoblock Finish -
Hoosier A6 315/30ZR19 rear -
Hoosier A6 235/35ZR19 front.
Sim sim eu sei a míuda, mas reparem também no carro... lol
Ui.. Belo :O~~
deve estar bem giro de andar com ele em pista eheh
ps - as gajas dos teus topicos são tão boas
2 old 4 this $hit
a gaja é de serie ou opcional?
Que besta esse lambo!
adorei td td td... O_O
