Resultados 1 a 4 de 4
Tópico: Forge Motorsport Fluoro Silicone Turbo Hose Kit For VW Golf Mk4 Diesel
    16.273
    Padrão Forge Motorsport Fluoro Silicone Turbo Hose Kit For VW Golf Mk4 Diesel
    Forge Motorsport has an enviable level of experience working with all Volkswagen Group cars, so it will come as little surprise to see their typically over-engineered solution to the turbo hose application on both 130 and 150 versions of the Mk4 Tdi.
    Even though Forge’s own silicon hose range uses the very finest European grade silicones, even this wasn’t considered to be tough enough for this extremely high temperature and potentially oil-laden area. For this application, Forge has specified a motorsport-grade fluoro silicone, complete with Nomex-reinforced lamination. The end couplers have been precision-machined from aerospace grade alloy, again to allow for extreme clamping and boost pressures.
    Finished in natural ochre this hose is ideally suited to being fitted close to the turbocharger and is easily able to withstand any oil that may accumulate in the hose, which would normally lead to degradation if normal silicone was used in its construction.
    Designed here in the UK and precisely manufactured to be a direct replacement for the OEM part. It’s a truly essential upgrade for any car that spends time on track, gets driven hard or that is running higher than standard boost pressure.
    Continuar a ler...
    Senior Member Super user Avatar de Bora
    Oct 2008
    Lagoa (Algarve) / Newark (USA)
    1.810
    Nada mal mesmo...pena só ser para os modelos em questão
    Rui sabes quais são os tubos em questão que estes substituíam?
    16.273
    a Forge tem uma gama cada vez maior, acho que consegues ver isso melhor no site deles.
    Oct 2008
    1.810
    No saite da Forge ainda explica menos que no saite do Link.....era só apara ver se dava para adaptar esse tubos no pd110 mas sendo assim.....
  1. Forge Motorsport Silicon Carbon Canister Hose Kit For Audi TT (Mk1)
    Última Resp.: 29-03-2012, 04:30
  2. Forge Launches New VAG 1.4 TSi Boost Hose Kit
    Última Resp.: 25-01-2012, 06:40
  3. Forge Coolant Hose Kit for VW Golf R
    Última Resp.: 27-10-2011, 06:01
  4. Forge Motorsport Audi Mk2 TTS Coolant Hose Kit
    Última Resp.: 26-05-2011, 02:00
  5. Samco 5 Piece Silicone Intercooler Hose Kit for 1.8T
    Última Resp.: 04-06-2008, 03:20
