Página 1 de 2 12 ÚltimoÚltimo
Resultados 1 a 20 de 25
Tópico: Escurecer opticas
    Jun 2005
    2.739
    Padrão Escurecer opticas
    Been looking for smoked e-codes for ages & finally found a site that stocks them. Got a bit of a shock when I saw the price :screwy: searched the tex and came across the “Joey mod”. It looked pretty champion so I decided to give it a go.
    This is the way I did mine but feel free to deviate.
    Here are some of the materials I used:
    1) Set of headlights
    2) A can of black high heat spray paint
    3) Small and large paint brush
    4) Clear silicone sealant
    5) Masking tape
    6) Tinfoil
    7) Butter knife
    Ear buds & Nail polish remover
    9) Flat Screwdriver
    Let’s get started:
    Step 1: Removing the front glass lens from the headlight.
    Remove the 4 metal clips securing the glass to the headlight backing using a flat screwdriver.
    Preheat the oven to 100 degrees Celsius.
    Once ready, pop the first headlight into the oven (yes the oven =) ) for around 60 – 90 seconds. This is totally safe and will cause the sealant to soften. Using a butter knife pry the glass away from the plastic backing. It should pull apart relatively easily.
    Step 2: Prepping for paint
    Using masking tape, mask off the edges you want the paint to go. You only want to be painting the rough chrome parts; the smooth parts reflect the light and should be left alone.
    Take note: The chrome reflective paint peels off rather easily so work cautiously. To combat the tape pulling off the chrome paint, stick the tape to your shirt a few times to remove most of the stickiness. This is a highly important step, the tape should barely stick.
    Step 3: Paint
    Spray some black high heat paint into a cup with a tinfoil surround.
    Using the big & small paintbrushes give the light a few coats of paint until nice and even.
    Take note: We noticed when painting close to the masking tape that the paint tended to get absorbed into the tape and run up into areas of the light we didn’t want painted. It was decided a vinyl type tape could possibly be a better option in preventing this. This wasn’t really an issue – refer to step 4.
    Step 4: Remove tape & cleanup edges
    Take care when removing the tape.
    Touchup any parts you might have missed.
    Using an ear bud dipped in nail polish remover clean up any bad edges.
    Take note: The nail polish remover works a treat but if kept on the surface too long it will eat into that precious chrome paint, therefore use as little as possible and clean it up shortly after with a soft damp cloth or kitchen paper.
    Step 5: Refitting the glass
    Re-silicone each light unit, fit glass and refit the metal clips.
    You are done!!!
    Stand back and give yourself a pat on the back and admire your handy work. Smoked e-codes WTF!!! :laugh:
    Not too sure but im thinking this is the first mk3 joey mod performed on South African soil.
    Bigups to Joey for making this mod possible!
    Some car punt pics :thumbup: :thumbdown:
    :P
    FUNCTION > form
    flickr
    Oct 2004
    OPORTO
    3.125
    Bom post, já tive de fazer isto no meu antigo mazda e foi este o processo que utilizei... Apenas não meti as opticas no forno, utilizei um secador para aos poucos forçar para abrir.
    Cumps,
    [::04"clio.dCi80RR::]
    Apr 2007
    lisboa/margem sul
    332
    Comprem um laguna... ja vem de origem!! eheheh :P
    abraços
    VW Bora 1.6 Highline
    Senior Member Senior
    Dec 2006
    520
    Epa acham que se eu meter uns angel eyes no forno o plastico nao vai derreter?
    pms
    pms está desconectado
    Member Novato
    Apr 2007
    38
    se meteres com o forno desligado n faz mal nenhum, hehe.
    epa isso se meteres a pouca temperatura n ha pro
    Nov 2007
    72
    fica muito fixe!
    Senior Member Super user Avatar de pistolas
    Apr 2007
    Vila Real
    1.586
    grande post.
    Cumps.
    Aug 2007
    Gondomar
    187
    grande post
    vai dar muito jeito
    Dec 2005
    141
    Fabulástico, granda dica para separar o vidro da óptica xD
    Senior Member Senior Avatar de pUbLIS
    May 2005
    Palmela
    993
    Bom post...
    Já conhecia a técnica, mas só depois de ler como deve ser é que percebi para que é que servia aquele copo com prata à volta.
    Se bem percebi, o gajo mandou o spray lá para dentro para ficar com alguma tinta disponivel, pegou num pincel e pintou aquilo à pincelada!?!
    Não me agrada muito este método.. depois é capaz de se notar esterias na área pintada. Acho que é preferivel isolar bem e pintar tudo a spray.
    Dá uma vista d'olhos nas minhas vendas de garagem
    VendasDeGaragem7
    Feedback
    @ 1stech
    @ Techzone
    @ TOL
    Member Average Avatar de RJ Wild
    Sep 2008
    67
    Grande post sim senhora bela ideia às vezes sai mais barato e damos mais valor quando somos nós a fazer!
    Sep 2008
    17
    5 estrelas! muito bom post!
    Member Novato
    Oct 2008
    32
    fica muito bonito
    Jul 2008
    317
    alguem pro a fazer isto???
    precisava que me fizessem nas minhas.
    pois eu nao tenho jeito nenhum pra isto...
    abraços
    Senior Member Average 2 Avatar de Dikon
    Aug 2009
    Santarém
    133
    Muito bom post
    Senior Member Super user Avatar de luis_td
    Sep 2009
    barreiro
    1.123
    boas, era mesmo isto qe estava a pensar fazer no meu ...
    mas na IPO n inplicam com isso??
    Apr 2009
    20
    Bom post... da muito jeito
    May 2007
    24
    Fica nos favoritos!
    Senior Member Average 2 Avatar de CorpsePT
    Oct 2010
    119
    Mês que vem vou experimentar isto!
    Jun 2008
    230
    Só uma cena que não percebi...
    Quando ele meteu as ópticas no forno foi para estufar ou para cozer?
  1. Escurecer Farois Traseiros ...
    Por DavidMRibeiro no fórum Geral Tuning
    Última Resp.: 17-12-2010, 12:58
  2. Escurecer opticas mk3
    Por miras_man no fórum Geral Tuning
    Última Resp.: 23-01-2010, 20:37
  3. onde comprar Pelicula ou escurecer vidros?
    Por ricardo_lima no fórum Geral Automóveis
    Respostas: 13
    Última Resp.: 18-08-2009, 23:10
  4. escurecer vidro
    Por benfica2006 no fórum Geral Automóveis
    Última Resp.: 08-05-2007, 09:25
