Respected global suspension manufacturer Eibach has released a new chassis upgrade for BMW’s latest F20 ‘1’ series. In addition to the range already available for the car, Eibach is releasing a set of lower ‘Sportline’ springs to improve on the car’s already impressive handling.
The new Sportline kit offers a significantly more aggressive drop than the existing Pro-Kit set-up. On most models these springs will create a 40mm front and rear drop from the factory ride-height. Thanks to a lower centre of gravity, not only are the car’s looks significantly enhanced, but turn-in and driver feedback are greatly enhanced.
Sublime handling is all very well, but not if it’s at the expense of ride comfort. Here, Eibach’s extensive experience in OEM-accessory programmes results in an almost factory-quality ride that perfectly matches the original dampers. This is achieved by Eibach’s progressive spring windings that effectively produce two spring characteristics in the one spring. Soft for straight-line ambling and precise for spirited cornering.
The icing on the cake comes in the form of the industry-leading 5 year, unlimited mileage warranty. For more information, please click to www.eibach.com.
More...
