Resultados 1 a 12 de 12
Like Tree1Gostos
  • 1 Escrito por claudiobs
Tópico: [DIY] Reparar linhas fundidas do display TID OPEL
    Sep 2004
    Odivelas * Benedita
    195
    Padrão [DIY] Reparar linhas fundidas do display TID OPEL
    Já pus este tópico no COPT, mas como também pode interessar pessoal que por aqui anda, cá vai:
    Como provavelmente sabem, um dos problemas dos displays da Opel, é que passado alguns anos, apresentam linhas fundidas, dificultando a leitura da informação apresentada.
    No meu caso já começaram a desaparecer algumas linhas e na Opel pediram-me cerca de 300€ para substituir o display.
    Procurei na net informação sobre este assunto e deixo-vos aqui o melhor que encontrei. Em inglês!
    Agora falta ganhar coragem e colocar mãos à obra!!!
    IMPORTANT UPDATE!!!! Please read...
    I tried to "repair" my TID with those instructions but I didn't success. I decided to find out what has gone wrong. Here is what I found.
    It is written:
    > Now using a Stanley knife blade, sc**** off the grey carbonised deposits
    > which will have oxidised onto the circuit board connector.
    Don't! The grey stuff is not a "carbonised deposit" but a conductive material, essential part of the flat "cable"! If you sc**** it off, the wire will be cut. For sure. If you disagree, I can provide Megs of digital photos taken by the digital camera installed to our professional 4x Leica microscope.
    If you want to do something more than adding pressure to the connection, I would prefer a conductive glue. And maybe some careful heating with hair dryer.
    > Be careful, we don't want to totally sc**** off the gold contact, just the
    > dusty white/grey stuff. Here's a picky of before cleaning/after cleaning.
    Well, you really don´t need to worry about that. To damage the gold plating, you need a HEAVY abrasion, or alternatively, a pretty sharp blade, stable hand and a set purpose to injure the plating.
    Br,
    Juha Ritala
    RF-Design Engineer
    Finland
    This How To explains how to repair your TID
    display once it has shown signs of fatigue by loosing parts of the display as shown below. As
    you can see, it's impossible to see the clock or outside temp, and the date/radio station is
    corrupted.
    Tools needed:
    For dash removal - Flat screwdriver, Crosshead screwdriver (magnetic if possible), 4 feeler
    gauges (I used normal kitchen knives)
    For digi repair - Small flat screwdriver, Soldering Iron, De soldering tool/wick (not
    essential), Stanley Knife, Old Toothbrush, Cable tie.
    First, you must remove the dashboard clocks. It sounds daunting, but it really is quite easy.
    The only fiddly bits are the vents really. I couldn't unscrew my steering wheel height
    adjuster, so I had to leave the bottom column shroud on, but that didn't matter. I must
    stress that you SHOULD NOT turn on the ignition with the dash
    out, this will trigger an airbag sensor fault which can only be reset by Vauxhall.
    Once the clocks are removed unscrew the two securing scres for the TID. This will allow the
    remove of the Digital unit and you should end up with this..
    To gain access to the module, you need to cut the "anti-tamper" lugs which are moulded into
    the sides do this with a Stanley knife.
    Now the back should come off and the internals should appear like this
    The next step is to de-solder the 3 contacts for the clock setting buttons. This is easier if
    you have a de soldering tool (RS part no 544-516) or some de soldering wick, obtainable from
    any electronics shop like Tandy etc.
    Once the contacts have been de soldered, you can remove the assembly like shown above.
    Now the only things holding the module in its casing are the retaining clips. Press these in
    and carefully draw the module out. This is what it looks like above.
    Mine is the simple "Triple Info Display (TID)" but the multifunction ones are similar. They have 1 long ribbon instead of 4 small ones.
    Here's where it gets a little bit tricky. Don't worry - it's buggered anyway so what have you got to lose ? Carefully begin to peel the ribbon away from the circuit board - NOT FROM THE LCD !!. Gently pull it downwards like this. Stop pulling once you ahve about 2mm of the contacts showing.
    Now using a Stanley knife blade, sc**** off the grey carbonised deposits which will have
    oxidised onto the circuit board connector. Be careful, we don't want to totally sc**** off
    the gold contact, just the dusty white/grey stuff. Here's a picky of before cleaning/after
    cleaning.
    Don't be tempted to jump to the next contact until the one you're working on is clean.
    It's totally boring I know, but you might as well do it properly now you've got the thing
    in bits. Try and sc**** along the length of the contact rather than across it. This is to
    reduce the chance of a short circuit. When you are happy the contacts are nice and clean,
    give them a gentle rub with an old toothbrush to remove any debris.
    Now it's time to put the thing back together. In addition to the "heated joint" method,
    Siemens have used a silicon band to apply extra pressure to the joint. We need to apply even
    more pressure to ensure a decent connection, so find something that will sit nicely
    underneath the silicon band, and is about 1 - 2 mm thick. I wouldn't recommend something
    that conducts electricity as this could short out the clock setting buttons when you replace
    the contacts. I used an 8" cable tie cut down to size like this....
    Hold each contact up with a small screwy while you solder.
    Now carefully replace the back part of the outer cover, clicking it's locking tabs into
    position. Remember there will be a little more tension due to the thickness of the cable tie
    sitting on the circuit board/ribbon cable joint. Now it's just a case of refitting to to
    your dash, then fitting that into the car.
    The end result.
    Thanks to Pete Evans for words and pictures
    http://opelmantaportugal.blogspot.com/ blog dedicado ao Manta A
    Astra 2.0Di
    tol_4speed@yahoo.com
    Senior Member Super user
    Sep 2004
    porto, matosinhos -> Lisbon, Upgrade
    1.604
    mt bem
    Jul 2004
    106
    vou tentar fazer isso num computador de bordo dum astra Di.
    cumps e Muito bom DIY
    SILVER TEAM:
    - Honda Civic EJ9 (1997), 90cv´s/6100rpm (stock)
    - Honda Civic VTI (199, 160cv´s/7600rpm (stock)
    Sep 2004
    Odivelas * Benedita
    195
    Citação Mensagem Original de Mata VTi
    o meu também é um astra Di com CB... ainda só não arranjei coragem / tempo para o arranjar!
    No COPT falaram-me também no DURALIT, que é um liquido para limpar pratas e cobres, que serve também para os contactos!
    Assim que puseres mãos à obra manda feedback! ou então melhor, tira fotos do processo!
    Astra 2.0Di
    Jun 2005
    212
    Citação Mensagem Original de 4speed
    O que é que os sprays de limpeza de contactos têm de errado?
    Sep 2004
    Odivelas * Benedita
    195
    Citação Mensagem Original de Junglas
    penso que nada ???!!!
    Se avançares com isso diz como correu!
    Astra 2.0Di
    Jun 2005
    212
    Num posso avançar pq num tenho um corsa nem nada que se pareça...
    Ja estou é "farto" de usar este tipo de spray para limpar contactos, desde de flats de aparelhagens, até potenciómentros de rádios. Além de limpar a porcaria que possa existir nos contactos, deixa uma camada protectora. Recomendo vivamente o uso deste tipo de sprays, em vez duralits ou outras invenções do género...
    Nov 2012
    Montijo - Seetúbal
    4
    Oi 4speed
    As fotos não aparecem.
    Já arranjas--te coragem para fazer.
    Pelo que li do teu topico se conseguir ver os passos e trduzir como deve ser sou capaz de arriscar pois o meu está uma lastima.
    sky
    sky está desconectado
    Z32 J spec 99 Super user Avatar de sky
    Sep 2003
    japan
    5.061
    Pessoal acho que é o Recorde de escavação?
    16.274
    por acaso tem havido uns maiores.
    Apr 2009
    1.434
    Era interessante haver uma organizacao nos DIY, tipo gerais vs marcas
    Sep 2010
    Sjm, Porto
    470
    Citação Mensagem Original de Black Dragon Ver Post
    E uma maior adesão na partilha de DIY que penso que nesta altura do campeonato sejam cada vez mais as pessoas a procurar soluções caseiras.
    Black Dragon gosta disto.
  1. Punhos, pedais, display 3 linhas ETC do 206 GTI
    Por striker_ no fórum Peças e acessórios
    Última Resp.: 14-12-2010, 22:35
  2. Display Multifunções 206 (CB)
    Por pUbLIS no fórum Peças e acessórios
    Respostas: 8
    Última Resp.: 23-08-2009, 16:38
  3. Display de Velocidade
    Por cup_uf no fórum Geral Tuning
    Última Resp.: 02-07-2009, 14:08
  4. Cargraphic 911 to be on display in Stuttgart
    Última Resp.: 16-02-2009, 01:40
  5. Display PPT40 (Computador de Bordo p/ 206)
    Última Resp.: 18-12-2008, 23:47
