Lowering your suspension is an amazing way to give your ride an aggressive look, add handling performance and vehicle stability and even help improve fuel economy. Your Audi A4 can benefit greatly from a lowering job. However, before you can lower your ride, you’ll need to find the right equipment for the job.
D2 has been crafting precision-engineered suspension components for import cars since 1997 and they really know their stuff. Enter the RS 35-Way Adjustable Coilover. Specifically designed for the Audi A4 1.8-liter Turbo (the 4-door, 2-wheel drive version), this coilover setup offers you incredible benefits. When they say 36-way adjustability, they really mean it.
The mounts are constructed of high quality, lightweight, powder-coated aluminum for the ultimate in longevity and performance. In addition, unlike other options on the market, these coilovers are made for your exact vehicle, which means you get the perfect fit, every time. That means no needless drilling or modifications are necessary.
Crafted for the road racer, these coilovers provide all the adjustability that you will ever need, in a sweet package. The style, color and design of these coilovers are unbeatable. The Teflon coating prevents rust from forming, giving you even more durability. In addition, they are sold in a set of four, which means that you don’t have to purchase multiple sets (and you save money and time).
Why do you need coilovers? Unlike lowering springs, coilovers provide almost limitless adjustability for your ride height. That means you get the ride that you want, rather than settling for a less-favorable setup. Coilovers are the best option for the serious tuner, though they do cost more than lowering springs alone. However, the investment is well worth it and allows you to attain a truly customized ride with a modicum of effort.
Installation is a snap, but you will need some tools. If you don’t have the tools to remove your struts and springs, you’ll need to take your car to a professional shop. This complete kit gives you everything that you need, including the strut, the coilover sleeve, the lowering springs and a camber kit to keep everything rolling correctly. If you demand the utmost in style and performance, D2 has the coilovers for your ride. This set can be rebuilt in the event that you wear them out, giving you a solution that will truly stand the test of time.
Continuar a ler...
