Ninguém tem uma ideia do que poderá ser?
A dúvida é a seguinte: Tenho aqui por casa um Fiat Punto de 2002, de caixa automática, e na caixa existe um botão com a letra "E" e eu não faço ideia para que serve :s Quando carrego nele aparece, no manómetro digita, por exemplo DE, ou RE, etc.
Alguém sabe do que se trata?
Vai uma foto:
Esse botão deverá servir para variar o modo como a caixa trabalha ...
vê se isto te esclarece..
"Technically the gearbox is called an MTA (Manual Transmission Automated) and consists of a traditional mechanical gearbox on which the manual leverage is replaced by an actuator that is electronically controlled by a TCU (Transmission Control Unit).
In detail, the gearbox offers 6 gears (plus reverse) with modes that are totally automatic and manual sequential with actuation. Here’s how it works.
In manual mode the driver can freely choose the ratio required by maneuvering the joystick gear lever on the dash. Obviously there is no clutch pedal.
In automatic mode the customer has the benefit of a variety of useful functions typical of the electronic operation of the gearbox:
- Uphill – Downhill Mode: gear changing logics operated by software to guarantee the best ratio depending on the slope in the road;
- Warm Up Mode: emission reduction strategy for cold starts;
- Brake Assistance Mode: reduction of ratios to support vehicle deceleration;
- Kick Down Mode: reduction in the ratio following abrupt acceleration (for example while overtaking);
- Fast Off Detection: gearbox inhibition if the accelerator is released rapidly.
It should be pointed out that in automatic mode, the Comfort-Matic offers various advantages compared to a manual unit. For example, maximum driving comfort, especially in heavy urban traffic, in addition to great driving pleasure due to the smoothness of the gearbox. In addition, pressing the “UP” button on the gearbox trim allows you to take advantage of a specific profile for driving in the mountains or in heavy load conditions. And again: the Comfort-Matic assures correct engine braking on steeply sloping roads while the control systems guarantee maximum reduction of transmission noise. Without mentioning that the new unit protects the drive shaft from overloading and offers less wear on brakes.
Compared to traditional automatic gearboxes, the Fiat Ducato’s Comfort-Matic offers lower weight (about 30% less), improved fuel economy, better energy efficiency as well as an appreciable reduction in the cost of maintenance and repairs."
Retirado daqui...
http://www.zercustoms.com/news/Fiat-...d-gearbox.html
Pelo que entendi, esse "E", é para a caixa operar de forma a poupar combustível, certo?
Cumps, e obrigado
Ok, muito obrigado a ambos pela ajuda
Realmente foi essa a minha primeira ideia, E = Economic, mas como não tinha bem a certeza e não tinha manual para consultar, preferi esclarecer a minha dúvida com quem sabe.
Boas a todos,
De novo o mesmo carro me deixou agora aqui com uma dúvida, desta vez muita mais séria...
Bem é o seguinte: O carro tem andado muito mal, o barulho do motor ultimamente tem sido bastante estranho, parecido com o daqueles carrinhos a bateria, e quando está completamente parado arranca de maneira muito estranha e além disso em subidas não desenvolve.
Uma coisa que reparei é que debaixo do manómetro das rotações uma luz vermelha com um desenho parecido com uma caixa de velocidades começou a piscar.
Já marquei um dia para levar o carro ao mecânico, mas gostava de saber se alguém sabe o que se poderá estar a passar...
PS. Foi feita uma revisão geral ao carro há muito pouco tempo e estava tudo bem.
Cumprimentos
