Resultados da Votação: corrado vr6 Vs golf 3 vr6
Votantes
64. Você não pode votar nesta votação
  • corrado vr6
    47 73,44%
  • golf 3 vr6
    17 26,56%
Resultados 1 a 7 de 7
Tópico: corrado vr6 Vs golf 3 vr6
    JT
    JT está desconectado
    Time Attack Super user
    Apr 2004
    Hamamatsu, Shizuoka, Japan
    5.134
    Padrão corrado vr6 Vs golf 3 vr6
    poix é ppl, sera q me podem dizer as specs destas 2 maquinas???
    eu ja tenho procurado na net mas n tenho enkontrado nd
    queria info do tipo
    0 aos 100
    0 aos 200
    vel. max
    cenas assim
    e ja agora qual e o melhor em geral
    2 old 4 this $hit
    JT
    Apr 2004
    5.134
    va la pessoal, ninguem sabe specs destes bolites??
    2 old 4 this $hit
    rc
    rc está desconectado
    Jan 2003
    253
    espero que responda
    1992 Volkswagen Corrado VR6
    bodywork
    Type 2+2 FHC
    Designer
    Number of doors 3
    dimensions & weights
    Wheelbase 2470 mm 97.2 in
    Track front 1425 mm 56.1 in
    rear 1380 mm 54.3 in
    Length 4050 mm 159.4 in
    Width 1796 mm 70.7 in
    Height 1310 mm 51.6 in
    Ground clearance
    Kerb weight 1240 kg 2734 lb
    Weight distribution
    (Front) 58.00 %
    Fuel capacity 70
    litres 15.4
    UK Gal 18.5
    US Gal
    aerodynamics
    Drag coefficient 0.320
    Frontal Area
    Cx
    engine
    Code
    Manufacturer Volkswagen
    Type V-6
    in 15° vee
    SOHC
    12 valves total
    2 valves per cylinder
    Main bearings 7
    Construction
    Bore × stroke 82.00mm × 90.30mm
    3.23 in × 3.56 in
    Bore/Stroke ratio 0.91
    Displacement 2861 cc
    (174.589 cu in)
    Unitary capacity 476.83 cc/cylinder
    Compression ratio 10.00:1
    Fuel system Bo Motronic M 2.7 fuel inj.
    Aspiration Normal
    Compressor type N/A
    Intercooler None
    Catalytic Converter
    Max. output
    (DIN) 189.6 PS (187.0 bhp) (139.4 kW)
    @5800 rpm
    Max. torque
    (DIN) 245.0 Nm (181 lbft) (25 kgm)
    @4200 rpm
    Maximum rpm
    Coolant Water
    Specific output 65.4 bhp/litre
    1.07 bhp/cu in
    Specific torque 85.63 Nm/litre
    performance
    Note: A value of -1 means that
    the car cannot attain that speed.
    0-50mph (80 km/h)
    0-60mph 6.40s
    0-100km/h 6.90s
    0-100mph
    80-120km/h
    (50-70mph)
    in top
    0-Quarter-mile 15.10s
    0-Kilometre 27.50s
    Top speed 233 km/h
    Fuel Consumption
    CO2 Emissions
    Power-to-weight 150.81 bhp/ton
    chassis
    Engine location Front
    Engine alignment Transverse
    Steering rack & pinion PAS
    Turns
    lock-to-lock
    Turning circle
    Suspension Front I.TB.MS.ARB.
    Rear I.ARB.
    Wheels F/R /
    Tyres F 205/50 R 15 85 V
    Tyres R 205/50 R 15 85 V
    Brakes F/R VeDi/Di-S-ABS
    Brake ∅ F/R / mm
    Braked area
    Transmission 5M
    Drive FWD
    Top gear ratio 0.84
    Final drive ratio 3.39
    1991 Volkswagen Golf VR6
    bodywork
    Type 4/5S HBK
    Designer
    Number of doors 3
    Wheelbase 2475 mm 97.4 in
    Track front 1455 mm 57.3 in
    rear 1439 mm 56.7 in
    Length 4020 mm 158.3 in
    Width 1695 mm 66.7 in
    Height 1405 mm 55.3 in
    Ground clearance 123 mm 4.8 in
    Kerb weight 1155 kg 2546 lb
    Weight distribution
    (Front)
    Fuel capacity 55
    litres 12.1
    UK Gal 14.5
    US Gal
    aerodynamics
    Drag coefficient
    Frontal Area
    Cx
    engine
    Code
    Type V-6
    SOHC
    12 valves total
    Main bearings 7
    Construction
    Bore × stroke 81.00mm × 90.30mm
    3.19 in × 3.56 in
    Displacement 2792 cc
    (170.378 cu in)
    Unitary capacity 465.33 cc/cylinder
    Aspiration Normal
    Compressor type N/A
    Intercooler None
    Catalytic Converter Y
    Max. output
    (DIN) 176.4 PS (174.0 bhp) (129.8 kW)
    @5800 rpm
    Max. torque
    (DIN) 234.0 Nm (173 lbft) (23.9 kgm)
    @4200 rpm
    Maximum rpm
    Coolant Water
    Specific output 62.3 bhp/litre
    1.02 bhp/cu in
    Specific torque 83.81 Nm/litre
    performance
    0-50mph (80 km/h)
    0-60mph 7.10s
    0-100km/h 7.60s
    0-100mph
    80-120km/h
    (50-70mph)
    in top
    0-Quarter-mile 15.70s
    0-Kilometre
    Top speed 220 km/h
    Fuel Consumption
    CO2 Emissions
    Power-to-weight 150.65 bhp/ton
    chassis
    Turns
    lock-to-lock
    Turning circle 10.60 m
    Suspension Front I.CS.ARB.S.
    Rear TB.TA.CS.
    Wheels F/R /
    Tyres F
    Tyres R
    Brake ∅ F/R / mm
    Braked area
    Transmission 5M
    Drive FWD
    Top gear ratio 0.84
    tá um pouco confuso, mas com um pouco de "treino" vai lá
    JT
    Apr 2004
    5.134
    obrigado
    2 old 4 this $hit
    Sep 2003
    VdL
    64
    De diferença de potencia e comportamento e aerodinamica escolhia o Corrado VR6, mas em lobo vestido com pele de cordeiro e melhores interiores escolhia o Golf III VR6...
    Stay cool
    Senior Member Average 2 Avatar de DoubleM
    Jan 2003
    Centro
    138
    Eu iria para o Corrado.. anda mais, e o look atrai-me mais, mas isso tb já depende do gosto de cada um.. quanto à versatilidade é coisa k provavelmente o Golf ganha pontos, por n ser um coupe...
    May 2009
    79
    e uma escolha dificil ambos sao grandes carros que adoro
    lol esa imagem do vw em cima do simbolo da honda ta brutal
  1. [Vendo] Jantes bbs originais de um Vw Golf GTD ou Corrado
    Por 20bruno no fórum Peças e acessórios
    Respostas: 6
    Última Resp.: 17-02-2011, 21:11
  2. Corrado G60
    Por Ricardo Gomes no fórum Geral Tuning
    Respostas: 26
    Última Resp.: 19-01-2010, 18:04
  3. vw corrado g60
    Por Damil no fórum Geral Tuning
    Respostas: 14
    Última Resp.: 29-01-2008, 20:35
  4. [Vendo] Chip Golf/Corrado G60
    Por XikoG60 no fórum Peças e acessórios
    Última Resp.: 25-06-2007, 19:31
  5. corrado g60
    Por tsunami no fórum Geral Tuning
    Última Resp.: 06-05-2007, 05:33
