Showcar BMW CS....nada mais, nada menos... M8 ? Nada tem nada de M8... M8 seria um coupé, este tem 4 portas... seria mais um concurrente do Panamera e do Rapide.
The Bugatti (TOP SPEED 406 KM/H) is out boxed, look at the specs. BMW has done it again, unlike the Bugatti and Mercedes, it has NO TURBO, NO SUPERCHARGER
Top speed Limited 462 km/h (288 mph)
0 - 100 km/h (0 - 62 mph) est. 3.5 seconds
0 - 200 km/h (0 - 124 mph) est. 9.5 seconds
0 - 300 km/h (0 - 186 mph) est. 22.0 seconds
BMW M8 SUPERCAR...
engine:65 Degree, Type F140 Aluminium V12 w/Performance Exhaust
position: Mid Longitudinal
aspiration: Natural
block material: Aluminium
valve train: DOHC, 4 Valves per Cylinder w/Continuously Variable Timing
fuel feed: Bosch Motronic ME7 Sequential Electronic Injection
displacement: 5988 cc / 365.41 cubic inches
bore: 92 mm / 3.6 in
stroke: 75.2 mm / 3 in
compression: 11.2:1
power: 708kw / 900bhp @ 8200 rpm
specific output:135.9bhp per litre
torque: 965 nm @ 5800 rpm
redline: 7800
body / frame: Carbon Fibre Body over Carbon Fibre Tub w/Rear Alloy Sub Frame
driven wheels: RWD w/TCS
wheel type: Special Lightweight Wheels
front tires: 265/35 ZR 19 Michelin
rear tires: 335/30 ZR 20 Michelin
front brakes: Brembro CCM (Carbon-Ceramic) Discs w/6-Pot Callipers, Power Assist ABS
rear brakes: Brembro CCM (Carbon-Ceramic) Discs w/4-Pot Callipers, Power Assist, ABS
front wheels: F 48.3 x 25.4 cm / 19 x 10 in
rear wheels: R 50.8 x 33 cm / 20 x 13 in
f suspension: Custom Sport Suspension
r suspension: Custom Sport Suspension
transmission: 8-Speed Semi-Automatic w/New Control Unit
clutch: High-performance Clutch
top speed: 462 kph / 288.75 mph
0 - 60 mph: 3.4 seconds
Espero que gostaram do que leram. Desculpem me isto estar em Inglês. Mas Assim ja sabem o que vem ai da BMW. Isto veio de uma fonte segura! O meu padrinho está em Africa do Sul e trabalha para a BMW e mandou me este email. Cumprimentos a todos =D
Última edição por cunegao; 27-02-2009 às 03:21.
Kitnoce Mobile :
Duvido piamente que isso consiga passar os 320km\h...
Sem qualquer apendice aerodinamico, quero ver como é que ele mantem a traseira colada ao chão para mandar esses 900cvs
'95 BMW E36 318Tds Touring
Nem terà 900 cavalos...
Kitnoce Mobile :
6000cc atmosferico com 900 cv ?! lololol se os engenheiros da F1 soubessem desta tecnologia....
Se meterem dois turbos nesse motor depois pode-se adaptar a um vaivem e a BMW depois pode começar a fornecer os motores para a NASA
Última edição por PilotoZetec; 27-02-2009 às 14:53.
O que tem de impressionante?!
http://en.wikipedia.org/wiki/McLaren_F1
Em 1993, BMW V12 6.1L com 627cv's.
Vais dizer-me que não conseguiriam fazer melhor agora, com mais 16 anos em cima de experiência e com novos materiais?!
Poupa-me... :P
LoL... enfim... ganda scoop !!!!
Kitnoce Mobile :
Ah!!
E o Veyron já não é detentor desse record à muito tempo!
Desde 13 de Setembro de 2007...
Aliás, está no livro do Guiness! SSC Aero TT com 412km\h...
Quem està a dizer mais barbaridades por aqui és tu Pedro... em atmo, nem pensar em chegar aos 900 cavalos sem aumentar a rotaçao... e mesmo assim... o motor do ENZO chega a 660 cavalos... o do FXX ultrapassa os 800 na ultima versão mas nao é homologado para a estrada... o SSC Aero TT é turbinado à força toda, o Veyron mesma coisa, o Koenigsegg tambem...enfim...tudo turbinado a partir dos 120 cavalos/litro... o que o PilotoZetec dis é que a partir dum certo nivel o motor não aguenta mais que x km...se queres mais potencia, é so turbinar...
Kitnoce Mobile :
LoL
As specs do V10 que estàs a falar eram as do motor de F1... quantos kms faz um motor de F1 antes de ser mudado ou reconstruido (não estou a falar das regras actuais...)?????
Quanto às fotos, o showcar foi apresentado em NY em 2007...2 anos.
O projeto foi abandonado pela BMW, pelo menos por enquanto, esperar por dias melhores.
Kitnoce Mobile :
O que disse, é que o motor do utilizado no Mclaren F1 era fiavel, não tinha tecnologia que não fosse já aplicada nos carros do dia a dia!
De um 6.1l consegiu-se 627cv's em 1993!!! Fiaveis e usaveis durante o dia a dia...
O que referi em relação ao Aero, foi só para dizer que neste momento o recordista de velocidade já não era o Veyron, como muita gente ainda o diz... apenas isso.
Aliás, o Mclaren F1 ainda é o recordista de velocidade em motor atmosférico.
397km\h...
PilotoZtec, apenas estamos a conversar, desculpa se te faltei ao respeito em qualquer momento.
O motor do McLaren F1 era uma besta, um grande motor !
Um dos ultimos trabalhos de Paul Rosche na BMW !
Simplesmente, mesmo tendo sido hà quase 20 anos, a evoluçao nao foi suficiente para chegar a tamanhas potençias em atmo, sem aumentar as RPM de maneira exagerada e que, certamente, teria consequencias na fiabilidade.
No quote que fizeste, eu estava a responder ao Artur Costa... até parece que as specs do motor F1 da BMW (quase 20'000 rpm.....) sao faceis de atingir... os motores eram mudados todos os GP ! Assim, claro que é possivel atingir potençias bestiais com atmos... mas sera que os motores aguentam ? Serà que os motores seriam agradaveis ? Nao esquecer que este BM seria um carro de 1800 - 2000 kg.. nada a ver com o McLaren F1, todo em carbono.....
O Aero SSC tem 6.2 e tem que recorrer a turbos para ultrapassar os 1000 cavalos... nao hà milagres sem turbo !
Última edição por kitnoce; 27-02-2009 às 16:40.
Kitnoce Mobile :
2002 BMW 320 TD M-Pack
2003 Tony Kart Mitox C/ Parilla IAME Leopard 125cc by NormaRacing
Um S2000 é muito vulgar ???? Haja guito !!!! LOOOOL
Nos ultimos 10 anos, que grande descoberta houve nos atmos que possa justificar tamanha potencia ??? NENHUMA !
Estamos a falar dum carro que possa ser utilisado todos os dias, sem necessitar 2 engenheiros cada vez que pegas no carro, que possa ser reparado na maioria das oficinas da BMW e que não necessite um serviço cada 1000km....
Como jà disse em cima, o Enzo dà 110 cv/lt...serà que o V12 do ENZO tem 660 burros em vez de cavalos ? Serà que o ppl do forum é capaz de criar um motor que cuspa 150 cv/lt em atmo e os engenheiros da Ferrari não? E o Enzo é de 2002... 7 anos... o FXX é de 2006, saca 800 cavalos dum 6.2... so que não é homologado... a ultima versão ainda dà mais cavalagem... mas sempre sem poder ser utilisado na estrada...
Kitnoce Mobile :
Sem turbos não me acredito que um 6000cc atmosferico chegue aos 900cv...
Injecçao directa diz te alguma coisa?
Estamos aqui numa discussão que ninguem tem dados tecnicos para fundamentar se é ou nao possivel.
V12 6L e 900cv é sem duvida um valor muito complexo principalmente n fazendo mais de 9000rpm e tendo de sair cm as regras de poluiçao vigentes. Sem estas duas ultimas alguem tem duvidas que era possivel e seria fiavel? (minimamente para o standard destes carros).
Agora posso juntar a "festa" mais um "suponhamos".
Ora se o Carrera GT tem um V10 5,7L cm 612cv tem quase 110cv por litro... o seu irmao mais novo ganhou cerca de 10% de potencia quando passou para injecçao directa... ora so ai ja temos quase 700cv(675+-) dum motor V10 5,7L. Isto sem grandes compromissos e novos desenvolvimentos avultados.
Agora é so imaginar um pouco mais de tecnologia posta a trabalhar num motor destes genero e concerteza nao ficara muito longe desses valores.
Isto sem recorrer a válvulas hidráulicas e peças capazes de fazer 15mil rpms.
Mas tanta coisa para algo que é so mais uma coisa escrita na internet... vai la vai.
