Pessoal novo preço 40€ cada ou 70€ os 2
Amplificador Jbl P80.2 60€
• Variable 12dB-per-octave electronic crossover allows the P-80.2 to be configured for a variety of applications
• High-output MOSFET power-supply topology doubles power into 2 ohms
• "Direct-Connect" allows choice of 4 - 8-gauge power and ground cable
• Die-cast chassis uses entire footprint for amplifier cooling - and it looks awesome!
Output 4 Ohms: 40W x 2
Output 2 Ohms: 80W x 2
Output 4 Ohms Bridged: 160W x 1
Signal-to-Noise (dBA): >110
Frequency Response (±3dB): 10Hz - 50kHz
Total Harmonic Distortion: 0.05%
Input Sensitivity: 250mV - 4V
Amplificador Kenwood Modelo KAC - 528 50€
KAC-528
Max Power Output (4 ?)
Normal............................................ .................. 70 W x 2
Bridge .................................................. ............ 200 W x 1
Rated Power Output (4 ?)
Normal (DIN45324, B=14.4 V) ...................... 35 W x 2
Bridge (1 kHz, 0.8 % THD) .............................. 100 W x 1
Rated Power Output (2 ?)
Normal (1 kHz, 0.8 % THD) .............................. 50 W x 2
Frequency Response ( 0, –1 dB) ........................ 5 Hz ~ 50 kHz
Signal to Noise Ratio ............................................ 100 dB
Sensitivity (MAX) (rated output) .......................... 0.2 V
Sensitivity (MIN) (rated output) ............................ 5.0 V
Input Impedance .................................................. 10 k?
Low Pass Filter (12 dB/oct.) ................................ 80 Hz
High Pass Filter (12 dB/oct.) ................................ 150 Hz
Operating Voltage (11 ~ 16 V allowable) .............. 14.4 V
Current Consumption (1 kHz, 10% THD) ............ 16 A
Dimensions (W ??H ??D)[mm] .............................. 220 x 55 x 160
Weight............................................ ...................... 1.8 kg
o material encontra-se a funcionar sem anomalias.
boas não queres um nokia 5800 express music pelos amplificadores??'
"Barraca Sport"
