Resultados 1 a 3 de 3
Tópico: Alpine CDA 9855R - radio / CD / MP3 + caixa de cd Alpine CHA-S624
    Member Average Avatar de velocity
    May 2004
    Algures na Margem Sul
    82
    Padrão Alpine CDA 9855R - radio / CD / MP3 + caixa de cd Alpine CHA-S624
    Tal como o titulo indica tenho á venda o antigo autorádio com muita pena minha....
    A qualidade do mesmo dispensa comentários....old school ...
    A caixa de cd´s é de 6cd´s....
    Está fora de questão a montagem do som que tinha no carro que tenho actualmente ainda para mais com mais uma pirralha na familia....
    Preço : 175€ (só vendo o conjunto)
    Product Type Radio / CD / MP3 player
    Series SwingFace
    Recommended Use Car
    Form Factor Full-DIN - In-dash unit
    Width 7.0 in
    Depth 6.3 in
    Height 2.0 in
    Weight 3.5 lbs
    Faceplate Type Detachable
    Equalizer
    Equalizer type Parametric
    Equalizer factory preset qty 9.0
    Equalizer user preset qty 6.0
    Audio System
    System Control Bus Ai-NET
    Sound Output Mode Stereo
    Sound Effects Media Xpander (MX)
    Equalizer Yes
    Controls Subwoofer level , Mute , Volume , Fader , Power on/off , Balance
    Max Output Power / Channel Qty 50 Watts x 4
    Crossover Active crossover
    Crossover Slope 24.0 dB/octave
    Built-in Display LCD
    Button Backlight Color White , Green
    CD Changer Control Yes
    Clock Yes (digital)
    Additional Features ID3 tags support , Title scroll , WMA compatible , Night dimmer , CD Text capable , Rotary encoder multi-control , Multi-angle mountable , iPod ready , GlideTouch bar , Satellite radio tuner control
    Radio
    Type Radio tuner - AM/FM
    Tuner Frequency Range FM: 87.5 - 108 MHz , AM: 531 - 1602 kHz
    Tuning Display LCD display
    Preset Station Qty 30.0
    AM Preset Station Qty 12.0
    FM Preset Station Qty 18.0
    Signal-To-Noise Ratio 65.0 dB
    RDS Yes
    Supported RDS Functions TA , EON , PTY , PS , AF , PI , TP
    Additional Features DX/LO switch , Auto Store (AS) , Station naming
    CD System
    CD system type CD / MP3 player
    CD system form factor In-dash unit
    Media load type Slot-load
    Playback modes One track repeat , All tracks repeat , Intro scan , Random play / shuffle , Repeat folder
    Digital audio standards supported WMA , MP3
    CD system response bandwidth -19995.0 Hz
    Signal-to-noise ratio 105.0 dB
    CD system total harmonic distortion 0.008%
    CD system dynamic range 95.0 dB
    Disc title memory Yes
    CD-R compatible Yes
    CD-RW compatible Yes
    Connections
    Connector Type Audio line-out
    Remote Control
    Remote control type Remote control
    Remote control technology Infrared
    Entrego em mão na minha zona de residência ou na zona do Campo Pequeno...
    May 2004
    82
    Pm´s respondidas
    May 2004
    82
    Continua á venda.....
  1. [VENDO] RAdio Alpine + Caixa cds Alpine
    Por nunocunha no fórum Peças e acessórios
    Última Resp.: 08-01-2009, 19:11
  2. [VENDO] Radio Alpine CDA-9855R
    Por D3ViL no fórum Peças e acessórios
    Última Resp.: 07-11-2007, 15:17
