Resultados 1 a 10 de 10
Tópico: Alarmes Pager
    Senior Member Super user
    Jan 2006
    Mem-Martins/Algueirão
    1.013
    Padrão Alarmes Pager
    Boas pessoal
    Tenho 2 alarmes Pager á venda (sem Starter)
    Adjustable Shock Sensor
    The shock sensor's sensitivity is fully adjustable. No more false alarms in a thunderstorm.
    Code Hopping
    This system uses code hopping technology to increase the security of the alarm. Using this technology will prevent anyone accessing your system with the reproduction of your remote signal by grabbing or scanning.
    Smart LED Indicator
    The LED will flash the same number of times as you would press the lock button. (with-in 5 second after you arm your car.)
    Door Status Warning
    The parking lights will flash to inform you that one of the doors is notclosed. In case where you temporarily park, such flashing may warn incoming cars.
    Status Memory
    In case when the system lost power, the system will remember the status before it goes off, when power restore the system will come online a the same state as before it lost power.
    Turbo Mode
    For cars equipped with a turbo engine. In this mode the engine will continue running for 2 minutes after the key is pulled off the ignition. This will provide a gradual idle cooldown and will significantly extend engine life.
    Remote Start
    In this mode, your engine will run for 10 (default) minutes then shut off automatically after that. You may also kill the engine remotely within these 10 minutes.
    Valet Mode
    The system works just as a keyless entry without any security function. You can use remote for locking & unlocking door, trunk release and car finding.
    Standard Arming Mode
    When armed, doors will be locked. System will also remind you to arm your car 20 seconds after the key is removed form the ignition and all doors are closed.
    Panic Mode
    Anti-Robbery - Anti-Jacking - Alarm sets off and parking lights flash for 16 seconds and then the engine will shut off even if key is in the ignition. The system cuts power off at the distributor therefore the car will not be started again until panic mode is existed.
    Multiple signal detection for remote start
    Tach, High-Voltage & Oil sensor
    Alarm Monitoring
    Once armed, the alarm will monitor the Shock sensor, Doors, Ignition, Boot and any optional sensor such as ultrasonic (not included). If triggered, the siren will sound and the remote will beep and show the triggered area as a blinking icon (see picture above).
    Six-tone 120db siren
    Compatibility
    This alarm works with factory security & remote entry systems. The remote can be used with or to replace your factory remote.
    The unit is equipped with an Ultra-Low Temperature Crystal and is designed to operate in temperatures around -40C.
    125€
    (por mais 25€ monto em carros até 2002)
    Última edição por Doell_60; 20-04-2008 às 09:02.
    Peugeot 206 1.4HDI MUX Black*
    195/50/15 GTI*
    LONG LIVE TUNING Average 2 Avatar de pamb1
    Nov 2006
    Caldas da Rainha
    377
    Boas.
    Como nao tens as caracteristicas, e melhor o teu ou este http://www.tuning.online.pt/forum/ve...es-t57960.html
    * * * Paulo Borges * * *
    Abraços e boas conduções
    Senior Member Super user Avatar de .Tiago.
    Oct 2006
    Olivais
    1.287
    Isso tá muito caro, tens de baixar o preço...
    Jan 2006
    1.013
    Citação Mensagem Original de pamb1 Ver Post
    Boas.
    No minimo o deasign e a possibilidade de Starter e Turbo Timer!
    e os preços já sao com Portes.
    arranjo mais baratos. Mas nao estes. So tenho 2.
    Última edição por Doell_60; 20-04-2008 às 09:11.
    195/50/15 GTI*
    Jan 2006
    1.013
    1 Vendido. Ja so fallta 1
    195/50/15 GTI*
    Jan 2006
    1.013
    Ninguém ker o ultimo?
    195/50/15 GTI*
    Jan 2006
    1.013
    Ninguém?
    É um bom alarme, boa qualidade e bonito.
    195/50/15 GTI*
    Jan 2006
    1.013
    Ultimo Reservado!
    195/50/15 GTI*
    Jan 2006
    1.013
    Quem quiser, posso encomendar mais.
    Proximo Stock, 110€ já com portes, directo a morada que pedirem.
    195/50/15 GTI*
    Jan 2006
    1.013
    Mais algum? Mandem PM.
    195/50/15 GTI*
  1. Alarmes pager funcionam mesmo?
    Por Lourenco_ no fórum Geral Tuning
    Respostas: 8
    Última Resp.: 20-05-2009, 22:26
  2. [VENDO] 3 Alarmes PAGER
    Por Doell_60 no fórum Peças e acessórios
    Respostas: 61
    Última Resp.: 18-06-2008, 11:31
  3. Alarmes Pager e sensores electromagneticos
    Por alt no fórum Peças e acessórios
    Última Resp.: 06-06-2007, 00:13
